Page 1 of 3
SUB-20 Slave Mode
Posted: Wed Jul 07, 2010 4:13 pm
by acalogirou
The hardware setup i am currently using is a SUB-20 in slave mode connected to a DSP board. The DSP is set up to run as an SPI master and the SUB-20 is running as an SPI slave. The software is being written using C#. Currently i am able to use the FIFO_Read function to receive a byte of information from the DSP. Depending on the byte received the SUB-20 then needs to return a certain amount of data. The master device is aware of the amount of data that should be received and has been programmed to clock this data through the SPI chain by sending dummy data. So far however i have not managed to get the DSP to receive the correct data back from the SUB-20. I am using the FIFO_Write function to send the data back however the values received are wrong. Has anyone else experienced any issues with running it in this way or know of any solutions. Cheers in advance.
Andy
Re: SUB-20 Slave Mode
Posted: Wed Jul 07, 2010 4:26 pm
Hi Andy,
Could you try to use the subtool GUI app to reproduce the issue?
Posted: Wed Jul 07, 2010 4:51 pm
You should also to be sure about the sequence of the read/write(s).
The SPI slave (as well as master) is sending and receiving data simultaneously. I mean while the bit is shifted out from master via MOSI the MISO is shifted in. So if your master shifts out 1 byte at the same time in shifts in 1 byte.
Posted: Thu Jul 08, 2010 8:54 am
by acalogirou
Current set up i am trying after the advice above is as follows:
Sub Tool:
  • SPI Tab
    Enable is Ticked
    Slave is Ticked
    Polarity is Rise
    Phase is SmplSetup
    FIFO Tab
    SPI is ticked
    Timeout is 1000
    Read Byte Count is 1
I then type in a message to send e.g 5 and press write in the FIFO tab. When i then run the code on the DSP i receive the value sent, 5.
When i try the equivalent in C# however it does not work:
Sub20 dev = new Sub20();
dev.Open();
dev.LDC_Write("\f");
dev.SPI_SetConfig(Sub20.SpiEnable | Sub20.SpiSlave | Sub20.SpiCpolRise | Sub20.SpiSetupSmpl);
dev.FIFO_SetConfig(Sub20.FifoSelectSpi);
byte[] output = new byte[1];
output[0] = 5;
int x = 0;
dev.FIFO_Write(output, 1000, ref x);
Using the C# code the DSP reads a value of 2.
Hope that all makes sense.
Andy
Posted: Thu Jul 08, 2010 9:40 am
You've missed phase:
Sub Tool:
Phase is SmplSetup
Code:
Sub20.SpiSetupSmpl
Posted: Thu Jul 08, 2010 9:47 am
by acalogirou
Phase has been included in the code snippet above and the list of values for the Sub-20 app.
Posted: Thu Jul 08, 2010 10:54 am
I mean you have different phase configurations in SUB Tool and in your program.
Posted: Thu Jul 08, 2010 4:03 pm
by acalogirou
Thanks for pointing that one out. I am now able to send one byte of data to the DSP. The new issue i beleive is to do with how the SUB-20 clocks the data in its FIFO to the DSP.
The c# program i run first does the following:
  • Setup the Sub20 as slave as shown above with the new phase used
    Create a byte array of size 2 (with values 10 and 20)
    FIFO_Write(array, 1000, ref x) where x = 1
I then run the code on the dsp that does the following:
  • Pull the SS Pin Low
    Send two bytes of data via MOSI
    Read two values received via MISO
    PUll the SS Pin High
What happens however is that if i run this code i only get the first value the first time. i.e 10 and then if i run it again i get the second value i.e 20. I believe this is because the SUB-20 is using the transition of the SS pin from low to high in order to tell it to send each byte of data as there is no option for sz in the FIFO_Write function in C#. Is this actually the case? The same thing happens if i use the app.
Cheers
Posted: Thu Jul 08, 2010 6:48 pm
No, this is not the case. SUB-20 slave is active as long as SS is low.
I wonder, if you push 2 bytes into FIFO why x=1 ?
Posted: Fri Jul 09, 2010 7:43 am
by acalogirou
Ah i assume from your comment that the "ref Description" value (i.e what i call x) in the FIFO_Read and FIFO_Write functions should be the number of bytes being sent and received. Cheers
