A to D Code.
kovelan
A to D Code.
Post by kovelan »
Maybe this should be posted in "Application" forum? --kovelan
 *   adn.c -- sub20 A to D ncurses __HACK__
 *   by kovelan (kovelan@yahoo.com)
 *   GROUND ALL UNUSED ANALOG INPUTS via 10k pulldown resistor.
 *   ADC inputs are positive only and up to VCC or Vref if less
 *   than VCC.  Analog scalers are needed if higher voltages are needed.
 *   NOTE: very ALPHA code, no warranty or libality if damage occurs
 *   to your systems.  Your on your own...
 *   gcc -o adn adn.o -lsub -lncurses -L../lib -L/usr/local/lib -lusb
 *   This should get the job done. Adjust to your build env.
 * "THE BEER-WARE LICENSE" (Revision 4.3):
 * <kovelan@yahoo.com> wrote this file. As long as you retain this notice you
 * can do whatever you want with this code. If we meet some day, and you think
 * this stuff is worth it, you can buy me a beer (or more) in return.
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <ctype.h>
#include <ncurses.h>
#include <unistd.h>
#include <libsub.h>
#include "cmd_pars.h"
#include "sub_app.h"
/* make everything global */
sub_handle       *fd;
int              rc=0;
struct           usb_device *dev;
int              gain=1,scale=1023;
int              adc;
double           Vref = 5.00;  /* normally used */
//double           Vref = 3.30;
/* ncurses globals */
int              current_getch;
int              doloop = 1;
static           WINDOW *mainwnd;
static           WINDOW *screen;
void screen_init(void)
    mainwnd = initscr();
    noecho();
    cbreak();
    nodelay(mainwnd, TRUE);
    refresh();
    wrefresh(mainwnd);
    screen = newwin(16, 30, 1, 25);
    box(screen, ACS_VLINE, ACS_HLINE);
/* only using 3 channels, easly expandable to more.  this was for use
 * with an accelerometer, so the X,Y and Z axis.
static void update_display(void)
    curs_set(0);
    mvwprintw(screen,1,1,"---------- AtoD ----------");
    sub_adc_single( fd, &adc, ADC_S2 );
    mvwprintw(screen, 3,6,"Ch2(X):   %1.5fV",  Vref * adc/scale/gain );
    sub_adc_single( fd, &adc, ADC_S1 );
    mvwprintw(screen, 4,6,"Ch1(Y):   %1.5fV",  Vref * adc/scale/gain );
    sub_adc_single( fd, &adc, ADC_S0 );
    mvwprintw(screen, 5,6,"Ch0(Z):   %1.5fV",  Vref * adc/scale/gain );
    mvwprintw(screen,10,6,"PRESS q TO END");
    mvwprintw(screen,12,1,"---------- AtoD ----------");
    wrefresh(screen);
    refresh();
void screen_end(void)
    endwin();
 *   main function()
int main( int argc, char* argv[] )
 *    find USB functions()
    /* Find USB device */
    dev = sub_find_devices( 0 );
    if( !dev )
        printf("\nError: sub_find_devices()\n");
        exit(0);
    while( sub_find_devices(dev) );
    /* Open USB device */
    fd = sub_open( 0 );
    if( !fd )
        printf("\nError: sub_open()\n");
        exit(0);
 * adc functions()
    config.adc_cfg|=ADC_ENABLE;
    rc = sub_adc_config( fd, config.adc_cfg );
    if( !fd )
        //endwin();
        printf("\nError: sub_adc_config(ADC_ENABLE)\n");
        exit(0);
    config.adc_cfg|=ADC_REF_VCC;
    if( !fd )
        //endwin();
        printf("\nError: sub_adc_config(ADC_REF_VCC)\n");
        exit(0);
 * ncurses functions()
    screen_init();
    while (doloop) {
      current_getch = getch();
      if (current_getch == 113) {
         doloop = 0;
      update_display();
      //usleep(500000);
        usleep(50000);
   screen_end();
   printf("\nTEST ENDS\n");
   return 0;
} /************************* end of main() **************************/
Re: A to D Code.
Can you tell us please what exactly this code is doing? Maybe a screen shoot.
kovelan
Re: A to D Code.
Post by kovelan »
In a nutshell, it as to read the 3 AtoD channels from an accelerometer (x, y and z), sleep() and start over using NCURSES
style display. (Ncurses makes for a nice text display. So, you must have ncurses installed on your system.)
Code is very adaptable to a more generic "read as needed" by adding or subtracting how many channels you need by
changing the update_display() function. Found out it is _important_ to have all unused analog inputs grounded with
a 10k pull-down resistor.
here is some non-NCURSES AtoD code. This allows one to choose which channel to read from the command line, but only
one channel at a time. (ie: "adc ADC_S0" for the first channel, "adc ADC_S7" for the last channel. (again alpha/beer code)
*   adc.c -- test adc
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <ctype.h>
#include <libsub.h>
sub_handle  *fd;
 *   main function()
    int         adc, gain=1,scale=1023;
    int         rc=0;
    if ( argc != 2 )
        printf("\nADC: must have 2 command line args.");
        printf("\nExample:  \"adc x\"   x = ADC_S0 (0 to 7).\n\n");
        exit (0);
    if( !dev )
        printf("sub_find_devices: %s\n", sub_strerror(sub_errno));
        return -1;
    fd = sub_open( 0 );
    if( !fd )
        printf("sub_open: %s\n", sub_strerror(sub_errno));
        return -1;
 * adc functions()
    if( !fd )
        return -1;
    config.adc_cfg|=ADC_REF_2_56;  /* NOTE: 2.56v reference */
    if( !fd )
        return -1;
    sub_adc_single( fd, &adc, argv[1] );
    printf( "\n%s:      %1.4fV\n\n", argv[1], 2.56 * adc/scale/gain );
    return 0;
