A to D Code.
Posted: Mon Aug 02, 2010 4:26 pm
Maybe this should be posted in "Application" forum? --kovelan
* adn.c -- sub20 A to D ncurses __HACK__
* by kovelan (kovelan@yahoo.com)
* GROUND ALL UNUSED ANALOG INPUTS via 10k pulldown resistor.
* ADC inputs are positive only and up to VCC or Vref if less
* than VCC. Analog scalers are needed if higher voltages are needed.
* NOTE: very ALPHA code, no warranty or libality if damage occurs
* to your systems. Your on your own...
* gcc -o adn adn.o -lsub -lncurses -L../lib -L/usr/local/lib -lusb
* This should get the job done. Adjust to your build env.
* "THE BEER-WARE LICENSE" (Revision 4.3):
* <kovelan@yahoo.com> wrote this file. As long as you retain this notice you
* can do whatever you want with this code. If we meet some day, and you think
* this stuff is worth it, you can buy me a beer (or more) in return.
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <ctype.h>
#include <ncurses.h>
#include <unistd.h>
#include <libsub.h>
#include "cmd_pars.h"
#include "sub_app.h"
/* make everything global */
sub_handle *fd;
int rc=0;
struct usb_device *dev;
int gain=1,scale=1023;
int adc;
double Vref = 5.00; /* normally used */
//double Vref = 3.30;
/* ncurses globals */
int current_getch;
int doloop = 1;
static WINDOW *mainwnd;
static WINDOW *screen;
void screen_init(void)
mainwnd = initscr();
noecho();
cbreak();
nodelay(mainwnd, TRUE);
refresh();
wrefresh(mainwnd);
screen = newwin(16, 30, 1, 25);
box(screen, ACS_VLINE, ACS_HLINE);
/* only using 3 channels, easly expandable to more. this was for use
* with an accelerometer, so the X,Y and Z axis.
static void update_display(void)
curs_set(0);
mvwprintw(screen,1,1,"---------- AtoD ----------");
sub_adc_single( fd, &adc, ADC_S2 );
mvwprintw(screen, 3,6,"Ch2(X): %1.5fV", Vref * adc/scale/gain );
sub_adc_single( fd, &adc, ADC_S1 );
mvwprintw(screen, 4,6,"Ch1(Y): %1.5fV", Vref * adc/scale/gain );
sub_adc_single( fd, &adc, ADC_S0 );
mvwprintw(screen, 5,6,"Ch0(Z): %1.5fV", Vref * adc/scale/gain );
mvwprintw(screen,10,6,"PRESS q TO END");
mvwprintw(screen,12,1,"---------- AtoD ----------");
wrefresh(screen);
refresh();
void screen_end(void)
endwin();
* main function()
int main( int argc, char* argv[] )
* find USB functions()
/* Find USB device */
dev = sub_find_devices( 0 );
if( !dev )
printf("\nError: sub_find_devices()\n");
exit(0);
while( sub_find_devices(dev) );
/* Open USB device */
fd = sub_open( 0 );
if( !fd )
printf("\nError: sub_open()\n");
exit(0);
* adc functions()
config.adc_cfg|=ADC_ENABLE;
rc = sub_adc_config( fd, config.adc_cfg );
if( !fd )
//endwin();
printf("\nError: sub_adc_config(ADC_ENABLE)\n");
exit(0);
config.adc_cfg|=ADC_REF_VCC;
if( !fd )
//endwin();
printf("\nError: sub_adc_config(ADC_REF_VCC)\n");
exit(0);
* ncurses functions()
screen_init();
while (doloop) {
current_getch = getch();
if (current_getch == 113) {
doloop = 0;
update_display();
//usleep(500000);
usleep(50000);
screen_end();
printf("\nTEST ENDS\n");
return 0;
} /************************* end of main() **************************/
