VB Form to read ADC results
Below code is a VB sample to read 8 ADC channels with ADC_Read
Public Class Form1
' Read all the 8 ADC channels 3 times i.e 8*3=24
Private Const SamplesToRead As Integer = 24
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Dim dev As New Sub20
Dim Data(SamplesToRead) As Integer
Dim Mux(SamplesToRead) As Integer
Dim i As Integer
' Open SUB-20 device
If Not dev.Open(0) Then
   MsgBox(dev.GetStrError(dev.GetLastError()))
   Exit Sub
End If
Do
   ' Enable the ADC and set Vref=Vcc
    If Not dev.ADC_SetConfig(Xdimax.Adc.Enable Or Xdimax.Adc.RefVcc) Then
      Exit Do
   End If
    ' Setup the Mux to read all the channels, i.e Ch0,Ch1,Ch2...Ch7,Ch0,Ch1.. etc
   For i = 0 To Data.GetLength(0) - 1
      Mux(i) = i Mod 8
      Next
    ' Read samples
   If Not dev.ADC_Read(Data, Mux) Then
      Exit Do
   End If
    Loop While False
      If dev.GetLastError() > 0 Then
      End If
   ' Close SUB-20 device
   dev.Close()
End SUB
End Class
sasha.tr
Re: VB Form to read ADC results
Post by sasha.tr »
Hi.
What is A/D precesion?
The A/D resolution is 10bit. Precision is +-2 lsb. For 3.3V reference it will be +-6.4mV
Reading ADC from Matlab R2009a, Sample code
disp 'SUB-20 ADC sample. Read 16 samples from CH1'
SamplesToRead = 16;
NET.addAssembly('C:\Program Files\SUB-20\bin\sub20net.dll');
% simulate do { ... } while(0) loop
for k=0:0
if ~ sub20.Open(0)
% Enable the ADC and set Vref=Vcc
if ~ sub20.ADC_SetConfig(sub20.AdcEnable+sub20.AdcRefVcc)
% Create .NET arrays
Data = NET.createArray('System.Int32', SamplesToRead);
Mux = NET.createArray('System.Int32', SamplesToRead);
% Setup Mux array to CH1
for i=0:(SamplesToRead-1)
Mux.Set(i,1);
% ADC read
if ~ sub20.ADC_Read(Data, Mux)
vref = 5.0;
Samples=zeros(1, SamplesToRead);
% Convert ADC samples to Volts
for i=1:SamplesToRead
Samples(i)= ( double(Data.Get(i-1)) * vref ) /1023 ;
err = sub20.GetLastError();
% Close SUB-20 device
sub20.Close()
if err > 0
fprintf('Error %d\n', sub20.GetLastError() )
error('Error!')
