with extensible semantics as a primary goal. Lua has a relatively simple C API compared
to other scripting languages. see http://www.lua.org
Below is a simple lua-script which demonstrates using SUB-20 ADC interface in lua script
-- This lua script demonstrates using SUB-20 ADC interface
-- The sub20dnc.dll must be located in the same directory
require 'CLRPackage'
import "System"
require 'luanet'
-- Load SUB-20 .NET component
luanet.load_assembly("sub20dnc.dll")
-- Import Sub20 type
local Sub20 = luanet.import_type("Xdimax.Sub20")
-- Create Sub-20 instance
local dev = Sub20()
local SamplesToRead = 16
local Data = Int32[SamplesToRead]
local Mux = Int32[SamplesToRead]
repeat
-- Open first available SUB-20 device
success = dev:Open(0)
if not success then break end
-- Enable the ADC and set Vref=Vcc
success = dev:ADC_SetConfig( dev.AdcEnable+dev.AdcRefVcc )
-- Setup Mux array to CH1
for i=0, SamplesToRead - 1
do
Mux:Set(i,1)
-- ADC read
success = dev:ADC_Read(Data, Mux)
vref = 5.0;
Samples = {}
-- Convert ADC samples to Volts
for i=1,SamplesToRead
do
Samples[i] = ( Data:Get(i - 1) * vref ) / 1023 ;
print(Samples[i])
print( "The script completed successfully !" )
until true
if not success then
print( "ERROR:", dev:GetStrError(dev:GetLastError()) )
-- Close the Sub20 instance
dev:Close()
