SUB-20 based Universal EEPROM Programmer
In forthcoming release SUB-20 Tool will contain new tab - "PROGRAMMER". It will provide capability to program most popular I2C EEPROMs. In future tool will be extended to program SPI EEPROMs and other IC's like micro controllers with ISP (In-circuit programming).
Re: SUB-20 based Universal EEPROM Programmer
subtool ver1.6.8 beta binary
You can extend the internal memory device list by
1) modifying the subtool application, i.e adding appropriate structure to the ProgDialog.cpp source file
/* i2c */
mem_dev_i2c_t def_i2c_dev[]=
{"AT24C01", 128, 8, 0x50},
{"AT24C02", 256, 8, 0x50},
{"AT24C04", 512, 16, 0x50},
{"AT24C08", 1024, 16, 0x50},
{"AT24C16", 2048, 16, 0x50},
{"AT24C1024", 131072, 256, 0x50},
{"24LC64", 8192, 32, 0x50},
2) adding I2C_DEV_XXX_Y parameters to the subtool.ini file at the end of [PROG] section. The subtool.ini file is located in the same directory i.e C:\Program Files\SUB-20\bin
For example:
[PROG]
DEVICE=6
I2C_ADDR=50
I2C_DEV_NAME_0=24LC64
I2C_DEV_ADDR_0=0x50
I2C_DEV_CAPACITY_0=8192
I2C_DEV_PAGE_SIZE_0=32
I2C_DEV_FLAGS_0=0
I2C_DEV_NAME_1=24LC256
I2C_DEV_ADDR_1=0x50
I2C_DEV_CAPACITY_1=32768
I2C_DEV_PAGE_SIZE_1=64
I2C_DEV_FLAGS_1=0
v1.6.9
-fixed bug related to waiting for i2c device ready during write operation
-added "verify" button
subtool169.zip
(142.84 KiB) Downloaded 2548 times
In SUB-20 Tool 1.6.16 added support for SPI devices.
Currently supported SPI devices are:
AT25Fxxxx
NMC93xx
Currently supported I2C devices are:
AT24CXX
24LC64
