sub-20 tool manual/guide
technerd
Post by technerd »
Hi
I was wondering if there is a guide or something for the sub-20 tool... the manual doesn't give me much clue how to configure the I2C...
Technerd
Technerd
Re: sub-20 tool manual/guide
Tell me what configuration do you need and I will show you how to do it.
SUB-20 Tool is a reference application provided with source code. It's main purpose is SUB-20 API C++ programming example.
technerd
Post by technerd »
I need to test some communication between an PCA9538 I2C expander by turning on and off the I/O ports of the expander
expander adresse: 70 & 71
bit 0-4
Technerd
This is what you need to do with SUB-20 Tool.
Press "Write" button to send 0x01 to PCA9538 at slave address 0x70.
dan
Post by dan »
How can I use the sub-20 tool to program a DS1307 serial I2C real-time clock? The Data Write sequence is as follows:
Start <slave address> RW ack <word address> ack <data(n)> ack <data(n+1)> ack ... <data(n+x) ack stop
S 1101000 O A XXXXXXXX A XXXXXXXX A XXXXXXXX A XXXXXXXX A P
Specifically, how do I add the multiple data when using the sub-20? Each data entry will represent the seconds, minutes, hours, day, date, month, year and finally control (0001 0011) mapped in the timekeeper registers from OOH, O1H, 02H, 03H, 04H, 05H, 06H, 07H repectively.
Also, what function is the GCE box?
dan wrote:How can I use the sub-20 tool to program a DS1307 serial I2C real-time clock? The Data Write sequence is as follows:
The GCE mean General Call Enable. It is used for configuring SUB-20 in Slave mode. (Not your case).
You need to fill in following:
Slave Address = 0x68 (1101000)
Memory Address = <word address>
Memory Address Size = 1
To read enter Read Byte Count - a number of registers to read. And press Read button
To write enter Data and press Write button
fox123
Post by fox123 »
I have the same problem for using I2C function by sub-20 tool.
I followed the setting description previously, but it seems not work.
How can I set the sub-20 tool to scan I2C device (or read I2C device register (address: 0x68h)).
Please provide some example step-by-step (include hardware configuration and operation), thanks.
Press "Scan" button in I2C tab
Fill in
Slave Address - depends on your slave device
Read Byte Count =1
Memory Address =0x68
Memory Address Size - depends on your slave device
Press Read
What you mean by hardware configuration? Connect I2C SDA,SDO
fox123
Post by fox123 »
That's right. I want to know how to connect I2C bus between sub-20 (GPIO header pin 1 and 2?) and the I2C header of my test platform,
or what kinds of problems should be take care (for example, the frequency)?
An another question, what does the "Issue I2C" buttons (start and stop) mean?
Thanks for your help,
Best regards.
Connect pins 1(SCL),2(SDA),34(GND) to corresponding pins on your test platform.
Any problems of interfacing two boards, i.e wires length, voltage levels, ground etc.
Issue I2C Start and Stop are are for low level I2C bus access. Normally you don't need this because start and stop conditions are generated automatically as part of any I2C transaction (read or write)
"Issue I2C Start" means "Generale I2C start condition on the bus"
"Issue I2C Stop" means "Generale I2C stop condition on the bus"
