Labview memory leak problem
To prevent memory leaks you should close all the .NET references opened in your vi. The following example demonstrates this
close_ref.zip
(13.8 KiB) Downloaded 3160 times
jon@ktizo.co.uk
Re: Labview memory leak problem
Post by jon@ktizo.co.uk »
The latest version of the LabVIEW driver fixes all the known memory leak problems:
viewtopic.php?f=2&t=506&sid=2327299497f ... 08ce#p1296
